#6208 - 10/13/23 12:55 PM E-Ray Hype Begins
GM lifted the press embargo, so the E-Ray hype is on
Most rags will kiss GM's ass to get a chance to get their mutts on a E-Ray smash and bash it, so read this and be done with it smile
Now comes the next evolution of the C8, the 2024 E-Ray, with a hybrid powertrain, all-wheel drive, and standard all-season tires that bring it ever closer to being a four-season supercar. And don't worry about it trading away performance in the name of saving fuel; it's fast. Very, very fast.
HIGHS: Massive and instant thrust, all-weather traction, sure doesn't drive like a hybrid.
Unlike the growing population of hybrid supercars, such as the Ferrari 296GTB and the McLaren Artura, the E-Ray can't be plugged in, and its motor is purely a power adder rather than an efficiency enhancer. The E-Ray's genetic makeup comes courtesy of both the base Stingray and the Z06. The Stingray donates its 495-hp pushrod 6.2-liter V-8, performance exhaust, and eight-speed dual-clutch automatic.
The Z06 lends its wider body, optional carbon-ceramic brakes, and steamroller-size tires—275/30ZR-20 fronts and 345/25ZR-21 rears. The hybrid system consists of a compact electric motor driving the front wheels that lives in a small space in front of the passenger cell, a 1.1-kWh battery stuffed into the tunnel that runs between the passengers, additional coolers to control battery temperature, and the software to make it all work.
The hybrid system fattens the power curve by 160 horsepower for a system total of 655 horses—just 15 shy of the Z06's output—and spins up 125 pound-feet of torque on its own. Hybrid propulsion isn't the only first for a Corvette, though.
The E-Ray is also the first Vette with all-wheel drive, as well as the first that combines carbon-ceramic brakes with all-season tires.
The E-Ray comes standard wearing specially developed high-performance Michelin Pilot Sport All-Season 4 rubber. While you may think, "Those are the widest all-seasons ever," we're here to remind you that the Lamborghini LM002's tires are as wide as the E-Ray's rears.
When the temperature heads south, the all-seasons promise more grip than the E-Ray's optional Michelin Pilot Sport 4S summer running shoes. After spending time with the E-Ray, we understand not wanting to park it when cold weather hits. With bags of instant low-end torque supplied by the electric motor, big V-8 horsepower, and the traction of all-wheel drive, the E-Ray delivers mega performance that's effortlessly accessible.
Our gorgeous Cacti Green test car arrived fitted with the summer Michelins (a $500 option) and track alignment settings dialed into its suspension.
Thusly set up, it used its adjustable launch-control system to best advantage, ripping off a 2.5-second 60-mph time—the quickest we've ever recorded for a Corvette and 0.1 second better than the fleetest Z06 we've tested.
The E-Ray's 10.6-second, 128-mph quarter-mile dash is 0.1 second and 3 mph behind the quickest Z06s over that distance; beyond that point, the Z06 gradually stretches its lead. The E-Ray's 1.08-g skidpad fling and 152-foot stop from 70 mph are behind the best the Z06 (with the Z07 track package) mustered, no doubt owing to the E-Ray's lesser tires and 3965-pound curb weight roughly 300 pounds of additional mass compared with the Z06. Both cars, according to Chevy, pull to similar top speeds: 183 mph for the E-Ray and 189 for the Z06 with the most aggressive aero add-ons.
The E-Ray, however, has inherited more than just Z06-like performance from its talented parents; its Stingray genes are obvious as well. Unlike the shrieking, feral Z06, the E-Ray is a domesticated beast, manifesting much of the over-the-road sophistication and refinement that we've marveled at in the base C8 with the Z51 package.
LOWS: Engine note lacks low-rpm drama, cabin could use more sound deadening.
The E-Ray rides almost as well as the Z51 Vette, thanks, magnetorheological dampers, though the hybrid's huge tires thwack tar strips more loudly and also transmit more of the road's graininess into the cabin. On twisty roads and off-ramps, the E-Ray answers the helm with virtually the same authority as a standard Stingray, going where you point it with a similarly settled, imperturbable feeling and far more grip than you can sanely exploit.
Braking is powerful and fade-free, with a slight softness at the top of the pedal travel where regen initiates.
We also sampled an E-Ray on all-season tires at the car's official launch in Colorado, and found its steering response and handling only a touch less crisp. According to the Corvette engineers, the all-seasons give up 0.1 g in maximum grip to the summer Michelin's, a difference that was impossible to feel while pushing hard on the winding roads around Colorado Springs.
To prove its claim that the E-Ray is trackable, Chevy let us log some laps on Pikes Peak International's roval.
Wearing its summer tires on optional carbon-fiber wheels, the E-Ray enjoys high limits. Its stable handling, ample grip, and faultless brakes make it easy to channel your inner Max Verstappen.
Press the Charge+ button, and the system keeps the battery feeding juice to the electric motor no matter how many laps you run. Shut off Charge+ when the battery is at 100 percent, and you have roughly two laps of full hybrid power—enough extra boost to add about 10 mph at the end of the curving back straight.
And should you feel the need to hoon, know that the E-Ray can perform lurid, extended drifts, something we pulled off within the confines of the track's skidpad area. On the street, Charge+ tops up the battery from 70 percent, we almost never saw less than that to fill in a minute or so.
Hybrid assist dials back as speed increases, decoupling completely at 150 mph.
The hybrid system's Stealth mode also enables you to sidestep the V-8's startup bark, which is loud enough to wake all the dogs in the neighborhood. You can slink away in dead silence on electric power and continue making like an EV for about five miles, as long as you don't exceed 45 mph.
Tickle the accelerator a bit too much, and the engine fires up. Among the other firsts, EV mode puts you behind the wheel of the first front-wheel-drive Corvette.
In normal driving, the V-8's engine note is as muted in Tour mode as it is in a Z51 equipped with the performance exhaust, which is standard here. The e-motor assist is so well integrated that without watching the readouts in the display, you'd never know when it's contributing power.
The system also seems to pay dividends in fuel efficiency. The EPA fuel-economy estimates for the E-Ray match those of the Stingray at 16 mpg city, 24 mpg highway, and 19 mpg combined, which means that, unlike the Z06, there won't be a gas-guzzler tax. In our 75-mph highway fuel-economy test, the E-Ray managed 23 mpg, and it averaged 16 mpg overall.
Provisioned with the 2LZ trim package, our test car bordered on luxurious. Of course, its domesticated nature goes full beast at any speed with a flex of your right foot. That, along with its newfound ability to accelerate hard in any sort of weather, makes the E-Ray both intriguing and compelling.
VERDICT: A highly evolved, thoroughly refined supercar that goes from sweet to beastly at the push of the throttle.
One thing we'd add to the E-Ray?
More sound insulation. At 70 mph, 76 decibels of road noise reverberated through the cabin, marring an otherwise comfortable long-distance cruiser.
Beyond that, all's right, including the price: $106,595, or $113,985 as tested not cheap, but a shocking amount of supercar for the money. Even with a six-figure price, the value trait carries on in this latest evolution of the Corvette species.
#6211 - 10/14/23 08:11 AM Re: E-Ray Hype Begins [Re: teamzr1]
1 registered members (teamzr1), 13 guests, and 10 spiders.
