#2746 - 08/15/08 08:29 AM Inability To Program Tire Pressure Sensors
PIC4946: Inability To Program Tire Pressure Sensors - keywords inflation inop inoperative learn low message monitor no receiver relearn RFA RIM service signal system TIMS TPM transmitter wheel - (Aug 6, 2008)
Subject: Inability To Program Tire Pressure Sensors
Models: 2005-2009 Chevrolet Corvette
Condition/Concern:
Tire Pressure Monitor System sensors may be difficult to program after tire or sensor replacement.
Recommendation/Instructions:
Verify the following....
Verify that all 4 tires are one of the following..
• Base Coupe and Base Convertible use - Goodyear Eagle F1, extended mobility
• RPO's - Z51 and Z06 vehicles use - Goodyear Eagle F1 Supercar, extended mobility
• RPO - ZR1 vehicles use - Michelin PS2, extended mobility
Verify that all the wheels on the vehicle are original OEM, not aftermarket or replica version of the OEM models.
Use a known good vehicle for test purposes.
See if the known good vehicle's tires will program to the troubled vehicle. Then see if troubled vehicles tires can program to a known good vehicle.
Note:
Prior to performing any repairs, document on the repair order the exact tire readings as shown on the DIC. Example(s) if the complaint is XX on LF and all other wheels are 30psi, write that down.
If the reading is "0" document which tire or tires are reading "0". This provides information when the repair order is read later.
#2905 - 11/15/08 04:46 PM Re: Inability To Program Tire Pressure Sensors [Re: teamzr1]
Tire Pressure Monitor Description and Operation
The tire pressure monitor (TPM) system warns the driver when a significant loss, or gain of tire pressure occurs in any of the 4 tires and allows the driver to display the individual tire pressures and their locations on the driver information center (DIC).
The system uses the body control module (BCM), driver information center (DIC), instrument panel cluster (IPC), remote control door lock receiver (RCDLR), a radio frequency (RF) transmitting pressure sensor in each wheel/tire assembly, and the serial data circuit to perform the system functions. Each sensor has an internal power supply with a 10 year service life.
When the vehicle is stationary, the sensors internal accelerometer is inactive, which puts the sensors into a stationary state.
In this state the sensors sample tire pressure once every 30 seconds and do not transmit at all if the tire pressure does not change.
As vehicle speed increases, centrifugal force activates the sensors internal accelerometer causing the sensors to go into rolling mode.
In this mode, the sensors sample tire pressure once every 30 seconds and transmit in rolling mode once every 60 seconds.
The RCDLR receives and translates the data contained in each sensors RF transmission into sensor presence, sensor mode, and tire pressure. The RCDLR sends the tire pressure and tire location data to the DIC via the serial data circuit where they are displayed.
The sensors continuously compare their last pressure sample to their current pressure sample and will transmit in re-measure mode if a 8.3 kPa (1.2 psi) change in tire pressure has been detected in either a stationary or rolling state.
When the TPM system detects a significant loss, or gain of tire pressure, the tire pressure monitor indicator icon is illuminated on the IPC and if equipped, a check tire pressure type message is displayed on the DIC.
Both the indicator icon and DIC message can be cleared by adjusting the tire pressures to the recommended kPa/psi and driving the vehicle above 40 km/h (25 mph) for at least 2 minutes.
If power is disconnected from the RCDLR or if the vehicle battery is disconnected each TPM sensor ID is retained but all of the tire pressure information is lost.
Under these circumstances the RCDLR cannot assume that the tire pressures were maintained over an unknown period of time.
If equipped, the DIC will display all dashes and the scan tool will indicate a default tire pressure value of 1020 kPa (148 psi) for each tire.
Driving the vehicle above 40 km/h (25 mph) for at least 2 minutes will activate the sensors causing the DIC to display the current tire pressures. The J-46079 TPM special tool may also be used to activate the sensors as well.
The RCDLR has the ability to detect malfunctions within the TPM system.
In the event a DTC is set, the tire pressure monitor indicator icon on the IPC will flash for 1 minute and then remain illuminated after the ignition is turned ON and the IPC bulb check has been completed.
Any malfunction detected will cause the DIC to display a service tire monitor system type message. For more information on other functions of the RCDLR, refer to Keyless Entry System Description and Operation .
#2908 - 11/16/08 05:19 PM Re: Inability To Program Tire Pressure Sensors [Re: teamzr1]
Also review this :
DTC and Scanner Information
1 registered members (teamzr1), 11 guests, and 6 spiders.
