#2347 - 02/03/08 09:32 PM vette not going to open loop during full throttle
mvvette97
I posted a while back I bought a pcm from a guy and he said he flashed a tune in it for the mods I have, well it does seem to run ok but I ran a short log the other day and noticed that it doesn't go to open loop at WOT. why would this be?
#2349 - 02/04/08 08:15 AM Re: vette not going to open loop during full throttle [Re: ]
Without seeing the tune I'd have to say if there is nothing wrong with any engine sensors then the tuner set the PCM table for when engine goes into closed loop with high temp values.
Common of cheaper tune when they do not want to fully tune is they set closed loop temp high thus sensors are ignored.
They could have forced the PCM into the old speed density mode so MAF is ignored thus so are the front O2 sensors.
If a sensor fails on startup then PCM would revert to SD mode.
#2352 - 02/04/08 12:02 PM Re: vette not going to open loop during full throttle [Re: teamzr1]
mvvette97
Thanks JR. How much would it cost me for you to just look at it? I don't really have the money right now to get one of your tunes because of an unexpected doctor bills but if you could look at it and tell me if it's crap then I guess I need to start saving to have you do a tune. I don't really want to drive it much if it's not tuned right.
#2353 - 02/04/08 12:11 PM Re: vette not going to open loop during full throttle [Re: ]
Email the flash file to me and I'll look at it and let you know what I see and then you can decide what you want to do about the tune
#2363 - 02/05/08 09:57 AM Re: vette not going to open loop during full throttle [Re: teamzr1]
I compared the tuned flash with a stock 98 and here is what changes the tuner did.
To what I see this was a partial tune and really should be dialed in for the makeup of that car and how you tend to drive it.
Comparison summary: 02:40:18 pm, Monday Feb 04, 2008
{B0105} Wide Open Throttle
CAL: "98" <-> ALT: "100"
{B0701} Catalytic Converter Protection Enable
CAL: "Disable" <-> ALT: "Enable"
{B1201} Abuse Management (in Gear) Upper RPM Threshold
CAL: "9999" <-> ALT: "2000"
{B1207} Abuse Management Vehicle Speed Threshold
CAL: "0" <-> ALT: "255"
{B1209} Abuse Management Time
Different from row 0 to row 15 inclusive.
{B3303} Fuel Cut-off Limiters in Gear
Different from cell: 0,0 to cell: 1,9 inclusive.
{B3618} PE Modifier Based on RPM
Different from row 5 to row 18 inclusive.
{B3605} Commanded Fuel When in Open Loop
Different from cell: 0,0 to cell: 16,12 inclusive.
{B5913} Spark High-Octane Table
Different from cell: 14,14 to cell: 23,16 inclusive.
{B5914} Spark Low-Octane Table
Different from cell: 4,0 to cell: 23,24 inclusive.
{B5908} Fuel Mixture Spark Correction
Different from cell: 0,7 to cell: 19,15 inclusive.
{B5915} Minimum Spark Advance
Different from row 7 to row 20 inclusive.
{B6603} TCS Spark Retard
Different from row 0 to row 19 inclusive.
{B6612} ETC Pedal Torque Limit Reduction
Different from cell: 0,0 to cell: 15,20 inclusive.
{C6001} Engine DTC Processing Enablers
Different from row 2 to row 172 inclusive.
{C5601} Misfire Detection Max Temp
CAL: "1" <-> ALT: "266"
{D1206} WOT Shift Mode Upper Threshold
CAL: "99" <-> ALT: "95"
{D1207} WOT Shift Mode Lower Threshold
CAL: "97" <-> ALT: "85"
{D1208} WOT Shift Mode Upper Threshold - Cruise
{D1209} WOT Shift Mode Lower Threshold - Cruise
{D1210} WOT Shift Mode Upper Threshold - 4WD
CAL: "100" <-> ALT: "95"
{D1211} WOT Shift Mode Lower Threshold - 4WD
CAL: "100" <-> ALT: "85"
{D0901} Part throttle 1->2 Shift Speeds
Different from cell: 0,0 to cell: 3,16 inclusive.
{D0902} Part throttle 2->3 Shift Speeds
{D0910} WOT 1->2 Shift Speeds, Normal
CAL: "42" <-> ALT: "40"
{D0911} WOT 1->2 Shift Speeds, Performance
{D0912} WOT 1->2 Shift Speeds, Hot
{D0915} WOT 2->3 Shift Speeds, Normal
CAL: "79" <-> ALT: "77"
{D0916} WOT 2->3 Shift Speeds, Performance
{D0917} WOT 2->3 Shift Speeds, Hot
{D0920} WOT 3->4 Shift Speeds, Normal
CAL: "130" <-> ALT: "134"
{D0921} WOT 3->4 Shift Speeds, Performance
{D0922} WOT 3->4 Shift Speeds, Hot
{D0925} WOT 2->1 Shift Speeds, Normal
CAL: "42" <-> ALT: "35"
{D0926} WOT 2->1 Shift Speeds, Performance
{D0927} WOT 2->1 Shift Speeds, Hot
{D0930} WOT 3->2 Shift Speeds, Normal
CAL: "78" <-> ALT: "73"
{D0931} WOT 3->2 Shift Speeds, Performance
{D0932} WOT 3->2 Shift Speeds, Hot
{D0935} WOT 4->3 Shift Speeds, Normal
CAL: "110" <-> ALT: "134"
{D0936} WOT 4->3 Shift Speeds, Performance
{D0937} WOT 4->3 Shift Speeds, Hot
{D0940} WOT 1->2 Shift RPM, Normal
CAL: "6100" <-> ALT: "6000"
{D0941} WOT 1->2 Shift RPM, Performance
{D0942} WOT 1->2 Shift RPM, Hot
{D0945} WOT 2->3 Shift RPM, Normal
CAL: "6100" <-> ALT: "5900"
{D0946} WOT 2->3 Shift RPM, Performance
{D0947} WOT 2->3 Shift RPM, Hot
{D0950} WOT 3->4 Shift RPM, Normal
{D0951} WOT 3->4 Shift RPM, Performance
{D0952} WOT 3->4 Shift RPM, Hot
{D1108} Desired 1-2 Shift Times
Different from cell: 0,0 to cell: 0,16 inclusive.
{D1109} Desired 2-3 Shift Times
{D1110} Desired 3-4 Shift Times
{D1002} TCC Apply Speeds - Third Gear
{D1003} TCC Apply Speeds - Fourth Gear
{D1005} TCC Release Speeds - Third Gear
{D1006} TCC Release Speeds - Fourth Gear
{D1009} TCC Throttle Release - Fourth Gear
{D0701} Base Pressure 1->2 Shift
Different from cell: 0,3 to cell: 0,32 inclusive.
{D0702} Base Pressure 2->3 Shift
{D0703} Base Pressure 3->4 Shift
Different from cell: 0,1 to cell: 0,32 inclusive.
{D0801} Torque Reduction 1->2 Shift
Different from cell: 0,6 to cell: 0,16 inclusive.
{D0802} Torque Reduction 2->3 Shift
{D2001} Abuse Mode RPM Enable
CAL: "5555" <-> ALT: "1200"
{D0301} Transmission Torque Reduction
{G1201} Anti Theft Configuration
CAL: "None" <-> ALT: "Class-2"
{G0901} Fan #1 Turn-on Temp
CAL: "200" <-> ALT: "226"
{G0902} Fan #1 Turn-off Temp
CAL: "194" <-> ALT: "219"
{G0909} Fan #1 Run-on temp
CAL: "200" <-> ALT: "284"
{G0910} Fan #1 Run-on time
CAL: "30" <-> ALT: "1"
{G0913} Fan #2 Turn-on Temp
CAL: "210" <-> ALT: "235"
{G0914} Fan #2 Turn-off Temp
CAL: "200" <-> ALT: "227"
1 registered members (teamzr1), 10 guests, and 7 spiders.
