Topics3,719
Posts6,913
#173 - 07/15/05 03:44 PM Some part prices and IDs
In doing work on right head, some of the parts needed :
12560745 2 med length head bolts $1.92
11588291 8 Long heads bolts $38
12558840 5 short head bolts $4.90
12558809 1 Right head gasket $27
12533587 8 Intake manifold gasket $56
12558573 1 Right exhaust gasket $9
12457652 8 intake valve seals kit $13
12533586 8 Ext valve seals kit $14
NGK TR6 8 Sparkplugs $13
AFS75 2 Front O2s $82
160748CC 8 Plug wires $108
#174 - 07/17/05 03:10 AM Re: Some part prices and IDs
I read that boosted engines benefit from 1/2 head bolts and O-Ringing the block, have you seen that anywhere.
#175 - 07/17/05 06:20 AM Re: Some part prices and IDs
The heads are part of the total engine strength and reason there is so many bolts per head that are also torque to yield type.
For boosted LSx engines I highly suggest the head is milled to support a metal O-ring which puts more strength pressure onto the head gasket to prevent gasket blowing out or slipping.
Being under boost the heads slightly lift up using a thicker bolts will prevent that lift.
I have suggested to my customers using boost to do this.
1 registered members (teamzr1), 14 guests, and 9 spiders.
